Should a tiller have a clutch?
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
10
IN
I rented a LP RTR1558 yesterday to prepare for our tree planting this weekend. In one area, I hit an ~8 inch rock and before I could react to the engine stalling and disengage the PTO clutch, it died. It fired right back up and everything seemed fine.
Was I doing something wrong?
Next time I guess Ill buy my own clutch if it doesnt have one or doesnt work properly.
4,067
YES it needs a clutch or shearpin or whatever 'they' call the REQUIRED safety device between tractor and tiller.
I've had 6" rocks 'magically' appear and the shear pin breaks ! Esy fix, drive to shed,find another pin, install, putt,putt back, then 1/2 hr later, BANG, anothr roak 'magically' appears....sigh. I'm thinking a small box with pins and wrenches ON the tiller is a good idea.
If you are 'solid' from tractor to tiller you WILL do damage( $$$$$$) , sooner of later.
I have no idea where my rocks come from, tilled it since 1999.
Jay
dlundblad
May 16, 2009
503
10
IN
Makes sense. The rental place is a hardware store.
Their rental tractors are commercial B26s and nearly identical in HP. Youd think they would know better.
dlundblad
May 16, 2009
503
10
IN
Jay
Ouch. Hopefully I didnt do any damage.
This is sickening.
SidecarFlip
Banned
548
Someone may have replaced the shear pin with a harder bolt
Bet they did. Kind of surprised it don't have a slip (friction) clutch on the driveline. My round baler has both. So does my disc mower and both have ratcheting clutches as well so as they wind down, the PTO is stopped.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,180
117
Coyote Flats,Texas
One hay season I baled with an experimental shear bolt assembly driveline on a rd baler & I hated it. I much prefer a slip clutch on the driveline.
May I ask what brand rd baler you have that turns so freely that it requires a ratcheting clutch? My rd baler stops immediately with or without hay in chamber when tractor pto is disengaged without a ratcheting clutch.
