Grand L6060 cat 1 or 2, 3pt hitch
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
146
59
Central, ME,USA
I am trying to find a hydraulic top link for my Gr L6060. The pin is 3/4" and the ball width is 1 3/4" on my tractor. From what I have researched this is a cat 1. Most of the cat 1 hyd cylinders are too short. The cat 2 cylinders are the right length and have a lot more push and pull power but the ball width is 2". (I only have 1 3/4") So how is the spec cat 1/2 for my tractor when the ball on the cat 2 is too wide to fit on the tractor. Its not the pin size. I understand I can get a cat 2 to cat 1 bushing it is the width of the ball. Am I missing something.
CapnDean
L6060,ZD1211
Feb 22, 2018
183
Gulfport, MS USA
I put a Cat II hyd top link on my L3901 - Same deal the Cat I did not have enough stroke or enough power. I used superglue and glued the bushing into the heim joint. I then ground off the excess with a grinder. Works great.
Dennis.D
Feb 16, 2018
146
59
Central, ME,USA
I just got a new cordless grinder for x-mass, I should have thought a that. Thanks guys. :D
AllDodge
M9540 RTV1100
Jan 19, 2019
191
South Central, ky
Just built one for my M9540, bought all the parts from the surplus center. I used a 2.5 inch cylinder, and may be a little light for my tractor, but time will tell.
Dennis.D
Feb 16, 2018
146
59
Central, ME,USA
Hey All Dodge, where did you get your cylinder? On line or do you have access to them at the stores in your area?
AllDodge
M9540 RTV1100
Jan 19, 2019
191
South Central, ky
Got them from the surplus center. They have some ready made's with smaller bore cylinders, but I bought a Cat 2 cylinder which required me to cut the cylinder eye end off and weld on a longer eye for clearance
https://www.surpluscenter.com/Hydraulics/
Bought all the parts individuality, hoses and all fittings
This is the ready made's, note (say top link) they have a longer fitting on the cylinder end, and some have check valves
https://www.surpluscenter.com/Hydraulics/Hydraulic-Cylinders/Tractor-Top-Link-Hydraulic-Cylinders/
This is the one I got and modified
https://www.surpluscenter.com/Brands/Wolverine/2-5x12x1-5-DA-Hydraulic-Cylinder-Wolverine-WWSB2512-S-9-12231-12.axd
edritchey
Ferris IS800Z - New Holland WM75 - John Deere X500
Jul 19, 2014
1,118
823
Wellsville, PA
I’ll see if I can get you the part number for just the hydraulic top link
