Kubota rtv alternator
Webn237
73
Southrn WI (Monroe)
I have a kubota rtv alternator on my d600 and was wondering if the T connector we necessary for charging the battery or can i just run 1 wire from the alternator to the battery for charging? I tested the alternator and it isn't charging at all with just the one wire. Is it suppose to be up around 12v or 13v?
Sent from my SM-G935R4 using Tapatalk
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
You need to run a wire to the "IG" terminal on the alternator that is turned on and of with the ignition switch. they are not "self exciting" alternators
Webn237
73
Southrn WI (Monroe)
Ok so I will order up a plug then. So one wire goes to the key or do both?
eserv
May 27, 2009
2,187
170
Hardisty, Alberta
Just one wire required to make the alternator work. The other teminal would go to a charge light.
Webn237
73
Southrn WI (Monroe)
I got the plug yesterday and hooked up the one wire like you said and works great! Thanks!
