Just purchased a L1501DT
Suthern61
L1501DT
Jan 24, 2018
East Bend NC
Hi all,
New owner of a fairly well kept 1501 but was wondering if there is anyone who can help with an operator/maintenance manual?
Thanks in advance....
5,257
1,043
Hi all,
Best first place to look is on Kubotabooks.com
Google "Kubota L1501 tractor data."
There you will find info but more importantly, the identity of the preceding and following models which makes finding material on Kubotabooks.com more successful to get manuals which will be close to yours.
You will see that the following model is an L1801.
Put your address details in your profile. Sometimes you may find another member close by.
I have had good luck with WSM for $9.99 from this site.
http://www.servicemanualvault.com/
If they have your model or an L1801 the material is excellent not fuzzy photocopied pages..
I keep finding material that may be relevant but I have not checked it out.
You should go to the GRAY section of this forum and look in the sticky post at the top which contains lists of Gray market machines. a L1501 might be one.
This info may give you a suggestion who might be able to supply relevant material
I now think you have a Gray tractor, Same Japanese quaility just not imported by Kubota USA. Sometimes the pto turns bacckwaards which caan be a problem.
This next link will take you to the manuals mentioned in the image posted earlier. The L1501 is specifically mentioned on the WSM cover.
https://www.dropbox.com/sh/umsvpn352rzjmab/AAArcXhWFfC_cNLiIssZxg_Fa?dl=0
