When working properly, selenoid gives loud click when key is turned on. Relay behind instrument cluster can be felt closing. I have swapped the identical glow plug relay with the selenoid relay with no change. When working properly, full voltage pulls the selenoid open when the switch is turned on. Lower voltage then holds the selenoid open down the second wire. I have already proven this as the problem first started on an intermittent basis. Sometimes power would be provided to the selenoid and then, next time, it would not be there. Repeated turning of the key had eventually started the tractor and that key turning had been something I repeated until I heard the loud selenoid click. It is now to the point no power makes it to the selenoid, no mater what I do and even after installing a new switch as a possible solution. This far, I have been unable to determine where the malfunction is taking place.
Remember we are trying to help not criticize you. We need to engage in a meaningful dialogue as you know your machine far better than anyone else can.
I was wrong in stating the solenoids job is to stop the engine. Just the opposite
I have studied and marked up one model's starting system wiring.
The red line is 12 volts direct from the battery, through a fuse #6 to the open contacts in the engine stop relay. This is power waiting to be switched on at which point battery power flows through the blue marked circuit to to the left hand coil in the engine stop solenoid.
Turning the key to Acc, On, or start positions sends power through the yellow marked circuit through fuse #8. This circuit does two actions. It closes the relay contacts by powering the small coil in the relay and now battery direct 12 volts is going to the engine stop solenoid LH coil through the blue marked circuit. The second action is to provide 12 volt power from the key switch to the right hand coil in the engine stop solenoid.
Would you have as test light like this one?
I do not believe the voltage to the engine stop solenoid changes. The pull in power of the two coils in the solenoid itself is different but both coils see the same 12 nominal volts.
From memory, you do not find any sign of 12 volt power on either of the two wires to the engine stop solenoid. This means that either two fuses are blown, #6 and #8 or there is a problem in the key switch
Can you please give me more specifics about your tractor so I can study the correct wiring diagram.
The WSM lists these different 5030 models and has a different wiring diagram for each of them.:
Manual Transmission ROPS type
Cabin type
GST model
HST model
This wsm material shows battery voltage sent to both solenoid circuits
This formal check of the relay may identify if there is a wiring problem. Squirrel chewed etc.
