OC455
BX2350 LED ROP, FEL, Belly mower,modified snow blower, pole boom, middle plow
As the title says, totally having a brain fart here.
As some of you guys know, I added my own hydraulic motor to my snowblower for the chute rotation and added a linear actuator for the chute deflector. I also added some LED lights to the chute for extra lighting so I can see where the snow is going.
I wired it up running off the battery so I could use it the previous winter. Wasn't really too keen on how that was setup.
I decided to run an auxiliary fuse block as Mr. Short has done. I have a 6 fuse/block with LED indicators. I have a 40amp relay to run off of the back of the factory fuse block (work light fuse) as it will only work with the key in the on position.
I figure this will tidy up the mess and will be much safer than what was there before (found a bunch of the wires somehow managed to come apart from the relay).
I have this type of light switch: http://www.allelectronics.com/mas_assets/cache/image/9/d/1/2513.Jpg
Where I am having a brain fart is how to hook up this style switch into the fuse block and have the switch work correctly. I figured out how to run the wires using the relay to the battery. Just not getting how to run it using a fuse block.
That and I want to get the winch I bought hooked up too. That's not really an issue.
