M110X Engine Warning Light comes on
CBart
New Castle, VA
Hi this is CBart,
I have a 2011 M110X tractor. It's running fine, but the red engine warning light comes on after operating for a while. There are no other warning lights. The warning light goes off when engine turned off and then comes back on after several minutes (sometimes 10-15 minutes, sometimes 30+ minutes). I'm looking for a diagnostic tool to interface with the tractor's software to find failure mode that's causing warning light to come on. Are there sensors on the engine I can check without the software. i.e. ensure good connection/loose connection, clean sensor, etc.?? Location? Is there a common cause for the warning light coming on? I'm not using tractor until I can determine and repair problem. Anyone had this problem? Thanks.
JerryMT
Jun 17, 2017
529
153
The Palouse - North Idaho
Hi this is CBart,
What dies the M110X operator's manual say about this? That's where I would look first. If you don't have an operator's manual than get one. You'll need it learn how to properly operate the machine and often times questions like yours can be answered by simply referring to it.
Have you talked to the local Kubota service department? That's where I'd go next if there was no info in the operator's manual.
huib
108s
Oct 25, 2014
canada
I have a 108s, which did the same thing, I tryed to figure out what kind of sencor would set it off, could not find out was told ,dealer has to come with laptop, but over the years a noticed it happened mostly when I got off the tractor, when it idled,so I increased the idle speed a bit, and it done it once again in about two years
