Hi All
I have just bought a 10 year old BX2350, which the previous owner had just used for grass cutting (middle deck). No manuals, but I have downloaded some. He had a GCD 600 BX grass collector which I have taken off in order to use the 3 point linkage.
Problem is, I can't lower the hydraulic arms on the back.
There is a lever on the right which raises and lowers the cutter deck ...is there a valve which directs the hydraulic oil to either mid or back hydraulics? How would you normally select which hydraulic arms this lever controlled?
There is a control wheel below the seat, pretty much in the midline, which I think may control speed of raising/lowering the hydraulics? I cannot rotate this ...guess it is seized....any suggestions on this?
The rear hydraulic arms are currently in the up position and have probably been this way for a long time.
Thanks in advance for any advice
Peter
Peter
