b2601 quick hitch?
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
328
89
Ottawa, ontario
Purchased a new B2601 and before next winter am going to install a front blower. What quick hitch part number and blower has anyone used. Just watched a video and supposedly the B2791A will fit and only have to shorten the mid drive shaft. Thanks.:D
thebicman
Feb 2, 2017
328
89
Ottawa, ontario
Hass anyone tried to fit a subframe for a b2920 to a B2601? Trying to gain some knowledge of what fits. Thanks.
BoltBuster
B2920, LA364, BH65
Apr 14, 2018
Hudson, NH
Reverse question: I have located a slightly used B2782B snowblower that comes with a B2714C quick mount. Is this the correct mount for my B2920 tractor?
thebicman
Feb 2, 2017
328
89
Ottawa, ontario
I eneded up buying a new blower with subframe. The B2714C is what I'm using on my B2601. The manual says the B2714C is for a B2650, B3350 B2301 and a B2601. But depending on model even the drive kit is different for this subframe.
JKTnAK
Alaska
Im in the same boat right now with a B2781B blower trying to figure out a way to get it mounted on my B2601. Do you know if the B2714C subframe is compatible with both the B2601 and B2781B and if so which drive kit I might need? I cant find any manuals online for the subframe and my local dealer is telling me Im sol and have to buy a whole new blower and subframe because the B2781B isn't compatible with my tractor, which is hard for me to believe.
thebicman
Feb 2, 2017
328
89
Ottawa, ontario
The blower looks very similar to my BX2755HD. As I stated the subframe I'm using with my B2601 is the B2714C. The drive line kit for it is a B2798. Hope this helps you.
