On my L260 at cold start the oil pressure at the plug on the oil filter which is right where the oil enters the passage to oil the engine reads 60 psi but the pressure at the oil sender tap is only 40 psi. After the oil warms up the pressure at the filter drops to 40 psi and the pressure at oil tap reads 23 psi. After more time the filter pressure drops to 30 psi and the oil tap drops below 20 psi and theoil light starts to flash. Some questions. What would make the oil tap pressure lower than at the filter? Can a passage be blocked? Wouldnt a leak anywhere show the same psi at both locations? Why the difference? Why does my oil pressure keep dropping?
I also found a lot of paper thin pieces of metal in the oil pan , some up to about 1/2 inch square.
Thanks for any help.
