Hydrolic dip stick poped out of the case
4,101
Guys after went and put the deck back on I noticed a pool of oil under the back of the 2360,, holy shyt whats this,,, the dip stick was just setting there on the hole,,, this sccares me cause i dont know if I may have knocked it loose by backing into something ,,OR,, the systen built up enough presure to pop it out.... Now if thats the case what would cause it to build up pressure I know there should be a reliefe valve or vent tube some place might that be pluged,,, mud wasps or maybe grass and stuff,,, what else would cause it,, and no I wasnt running it hard just a clean up mow job
kuboman
721
Check your vent. Is your tractor stored outside? If it is your tranny may be full of water.
