Hydraulic top link, tilt, and angle
kzkydh
L3940 HST Grand
Feb 8, 2014
Ortonville, MI
Hi,
I have a Kubota L3940 HST and want to add hydraulic top link, tilt, and angle for use with my Land Pride RB2584 back blade. I am trying to determine all the components that I need and where to get them. I have found plenty of sites selling components, but not enough detail to determine which components are right for my application.
I think I need the following:
1) 3 lever valve system (really do not want to link into my bucket controls, as I use both the blade and bucket at the same time often.
2) Hose kits
3) 3 hydraulic cylinders
4) fittings to link into my Kubota hydraulic system
That is about all I know at this point. Any advice for the experts here would be great.
1) What should I buy?
2) What are my options?
3) Where is a good place to buy?
4) Have any good instructions on how to build?
5) Does the angle solution for a back blade have enough strength since the pin will be removed?
6) Where is the right place to mount the additional control lever?
7) A link to what Kubota offers? (I could not find)
Thanks a bunch!!
rparkinson
297
Northport Maine
Same here. I was going to do the same, but for the money just call Brian. he has a good product, and fair prices. Not to mention he is always there after the sale. he is a good guy. In the long run you will have a better product, probably for less money by the time you get done.
MtnViewRanch
869
308
Lakeside Ca.
Hi,
2) Hose kits
Thanks a bunch!!
I highly recommend that you get no smaller than a 3" dia cylinder with a 1 1/2" dia rod for the angling of your RB2584# And actually a 3 1/2" dia cylinder would be better.
No pins on this blade and it's plenty strong. You need to be sure that the mounts at both ends are strong and get the right size hydraulic for the application. And get the hydraulic before you make your mounts. ;)
