AC was cooling fine yesterday & early this AM. I blew out exterior of radiator & condenser with an "air comb". Not much dust or chaff blew out. Cleaned both cab filters. Checked to be sure AC comp belt is snug. Installed AC gauges,pressures were 52# & 300#. I think orifice must be clogged. This AC system hasn't been disassembled since I purchased it used with 137 hrs on speed/hour meter in 2012. Thanks for any ideas,Jim
Jim
Did the end of AC output occur and then you cleaned out the heat exchangers, or did cleaning the exchanges result in no AC?
The system is trying to maintain certain pressures, mostly the evaporator pressure, through an expansion valve and cycling the compressor.
You don't mention what the AC compressor clutch is doing. Running all the time, cycling or not running most of the time.
The factory WSM contains an easy to follow test procedure which has you bypassing all controls and powering the compressor continuously from the battery for 5 minutes to allow the system to stabilize all the while monitoring system pressures and the presence and frequency of bubbles in the receiver sight glass.
Having the same year M7040 makes me think that you too have a very small leak and the system has just lost enough gas to stop running.
Getting into an extensive investigation will involve opening the system with all that entails.
18 wheeler's AC are serviced all the time by mobile mechanics who come to you. At this stage, a Kubota mechanic is not necessary. What you want is a through leak detection, perhaps with the addition of a UV dye, and then a recharge.
If the recharge does not get the pressures into the proper range (which at 86F outside air would be 21-28 psi and 185-242 psi.) then more involved work is necessary which will be much more expensive.
My suggestion is a bit of a gamble but one I think is worth the risk.
Dave
