Anyone know the Thread type for Part number 7J417-71170 Thanks
https://apps.kubotausa.com/illustrated-parts/
Tractor is an M5140 HD no cab shuttle shift with a LA 1153 loader with 3rd function valveYour link doesn't go anywhere but Kubota's home page and you can't link to individual Kubota pages.
It helps when your referencing parts that you tell what they are used on, that part is used on a ton of loaders, is that what your needing it for?
I can't tell you what the adapter thread is, it's probably something like JIC to BSPT, but without one in front of me can't tell.
Why do you need to know?
Thanks this is what I know about BSPT, BSPT ConnectionsIt is possible that they are NPT, I'm not 100% sure on newer loaders.
First remove the fitting and make sure it doesn't take an O-ring to seal or a flare, if it doesn't and the treads appear to taper, get a 1/2 NPT fitting and see if it will thread on at least 3 threads without binding, if it does not, usually about 1 1/2 threads it will start to bind, then it's BSPT.
When you take off the fitting if you would take a quick picture of it and post it, I might be able to give you a better answer.
I emailed my dealership parts This is what I get backYep you got it right, that's why if you try and dry fit a NPT fitting on it and it stalls in a short time it's a BSPT fitting, and if it free threads it's a NPT fitting.
Kubota used to use only BSPT and BSPP fittings, but not so much anymore, especially when it's on the loader.
