Yes, like the post said no power to fuel cut off solenoid.Saul,
welcome to the forum -
If all of a sudden and fuse is good - you check for voltage to solenoid?
I bench test the solenoid and it's good. Plug the solenoid back in and grounded it, turn the key and nothing. Got my test light out and test both the hold and switch power to the plug and nothing. Checked all fuses and they are good.What would cause no power to the fuel cut off solenoid? I have checked all fuses.
Thank you
Saul
There are 2 fuses 5 amp and 30 ampI bench test the solenoid and it's good. Plug the solenoid back in and grounded it, turn the key and nothing. Got my test light out and test both the hold and switch power to the plug and nothing. Checked all fuses and they are good.
Is there a relay to the fuel cut off solenoid?? Or is it controlled by the switch?
This tractor only has 200hrs on it.
Alright, excellent! Where is this relay located?
No, it will not start. You can normally hear the solenoid click when you turn the key on, the plunger pulling in to let fuel flow. Now nothing. Like I said previously I took it out and bench tested it. It works fine. All fuses are good. From my research, the solenoid is grounded to the block/pump, one of the two wires to the solenoid is a hold to hold the plunger open and the other switched to the key. So I'm assuming the relay went bad as the tractor is practically new.FYI: The solenoid is only powered on shutdown.
So it runs and you can't get it to shut down right?
The STOP solenoid (not Run solenoid is powered when it stops not starts).No, it will not start. You can normally hear the solenoid click when you turn the key on, the plunger pulling in to let fuel flow. Now nothing. Like I said previously I took it out and bench tested it. It works fine. All fuses are good. From my research, the solenoid is grounded to the block/pump, one of the two wires to the solenoid is a hold to hold the plunger open and the other switched to the key. So I'm assuming the relay went bad as the tractor is practically new.
It's #7 and if some location.
It does I already did this.The STOP solenoid (not Run solenoid is powered when it stops not starts).
Pull the solenoid off and see if the tractor starts, bet it does if everything else is right.
The relays are under the dash panel, open the hood and look under the dash or you will have to pull the cover.It's #7 and if some location.
Thank you for the info.
Bit I
Cool, but I'm assuming there's more than one? There's one on what I would call the fire wall. But from what I have seen there are more under the dash panel. I was hoping for a detailed location?The relays are under the dash panel, open the hood and look under the dash or you will have to pull the cover.
There is only one fuel cut off solenoid, so I'm confused as to what you are saying.The STOP solenoid (not Run solenoid is powered when it stops not starts).
I'm going by what the WSM states.There is only one fuel cut off solenoid, so I'm confused as to what you are saying.
The fuel cut off solenoid dictates run and off, solenoid plunger pulls in and it runs, plunger drops it turns off. Hence why I pulled it to see if it would start and it did.
So why are you saying they're different?
Those wanting to troubleshoot electrical should pay close attention to what you said. Not only does it bring to light that problems are often simple as disconnected wire,it carries a hidden message of what caused wire to fall off. The fact wire was corroded well back up into insulation means it began with high resistance contact between wire and terminal (poor crimp) or between terminal and post on fuse holder. Be on alert for discolored terminals while preforming routine maintenance. Terminals often preform for days are weeks after initially discoloring before totally failing. High resistance is like a snowball on a hill, it feeds from it self while growing bigger/worse.In my case where my engine would not start, it was a corroded wire leading into the 30A fuse holder for the key stop solenoid. I had no power on either side of the fuse when I tested it. The supply wire simply fell out of the crimp terminal. I had to open up the loom and keep cutting back the wire until I had clean copper again.
The key stop solenoid relay is right above the 30A fuse holder.
