Keep in mind that the larger central area of the shaft is sealed pretty tightly against the housing….and when grease is pumped IN…. once the cavities which are supposed to be greased are full of grease…any additional will escape the easiest pathway…. which due to the close fitment of the shaft with it’s housing…. the easiest path is back thru the splines.
The fact that only clean grease is being observed is of no concern….. the clean/fresh grease arrives at an already full cavity…and cannot enter….so exits via the easiest pathway. The indicator that the needed amount of grease is applied….IS the visible escaping excess.
Relax.
Do this every 100 hrs.
Relax.
