It tells us that the "Boom" is for a LA272 and LA302 loader.I did uncover these numbers under the paint. Any idea's.
ThanksIt tells us that the "Boom" is for a LA272 and LA302 loader.
Nothing a flap wheel wouldn't take right back out. Hazard of painting stuff lol.You should probably be a bit careful about how much paint gets into the holes for the pivot pins. It could cause some problems when you get ready to re-assemble everything.
Thanks, I'm going to clean out the Pin boss's before the Pin's go back in.You should probably be a bit careful about how much paint gets into the holes for the pivot pins. It could cause some problems when you get ready to re-assemble everything.
I haven't used it myself but after doing some body work I heard there is weld thru primer used in automotive work. It supposedly used to coat parts then when welding the back sides don't rust. Something maybe you could try when you laminate those to weld them on if you haven't already?Put in a few hours after work today.
To make myself feel better I'm going to reinforce the Side Frames.
1st I made a template.
And then using some 1/8" plate I cut out some blanks to make the reinforcement plates.
The blanks are approx. 7"x20".
Cut the metal with my HyperTherm plasma torch.
I stacked the plates up and tack welded the edges together.
This way all the reinforcement plates come out the same.
Then traced the pattern onto the metal.
Used a 2" and 1"3/4" Bi-metal hole saw in my drill press to make the holes.
Once the holes were made I cut the blanks to shape.
After a little grinding and fitting the reinforcement plates fit nice.
Then I threw them in the blast cabinet and got all the surface rust off.
This is the media I use in my blast cabinet.
Both are a none silica media. The black one is more aggressive than the white one.
I get it from a local quarry. $13.00 a bag.
All clean and ready for welding and paint.
That's it today.
