Update-
Injection pump failed when the shop tested it and he said the injectors were not "failing" but he said it was close to their standards.
So pump and all three injectors were rebuilt. I installed everything last night and she runs pretty dang good. Only thing that stood out is a slight delay when its sitting at idle and i throttle it up...?its not choking out or sputtering or anything .....Might be normal for this tractor i'm not sure.
EDIT*- Now that i type it out and think about it I think it hesitated idling down as well... kind of odd, i didn't remove the throttle lines or mess with the adjustment.
Either way here are some numbers for reference if anyone is in the Houston area looking at the same project.
Facility I used was M&D Distributors
Injection pump total cost on rebuild and test was $500
Each Injector test and rebuild cost was $105
I did replace the hard metal "Fuel Reclaim" line that runs between each injector due to the "crap" that i blew out of it, it was kind of difficult to clean so i just replaced it to be 100%
Fuel Filter replacement, and fresh oil change.
All in All right at $1100
