L245 low oil pressure when hot
Fsmith
L245
Aug 7, 2015
green cove springs
New development...my L245 oil pressure drops off to below 7 lbs at idle and 25 lbs at 2000rpm. Should be 14 and 45 which is what it is when first starting the engine. As it gets hot the pressure keeps dropping. I'm aware of the problem with the cam shaft plugs falling out but I have good pressure when cold. Is it possible the plug is loose and not completely gone at the cam shaft. Thanks for your input!
5,272
Anything is possible, ;), With the plug completely out it could still have good pressure till it heats up and then the gap gets bigger and the oil get thinner. :cool:
universal 5424
universal 5424 marine diesel engine dh1101
Nov 20, 2011
marathon fl
Cam shaft plug problem? Whats that? My just rebuilt dh1101 engine (l245) is also loosing oil pressure when hot - just under 40psi....the temp guage is steady at 77 deg C but starts to expel coolant...
Sent from my ASUS Transformer Pad TF300T using Tapatalk
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
If your cam plug is good, check the oil sump screen, and the O ring. I had a 185 once, that the O ring got hard and wouldn't seal... Cheap fix, oil pan gasket and O ring...:D
