Hello all can your tractor work without issues without having the thermometer switch installed. The temp gauge never worked since I own the tractor even after replacing the thermometer switch and thermostat. The water pump and fans operate normally and circulate water.
I am installing a new cylinder head (after market) and the new head did not have the whole drilled for the thermometer switch every other hole and parts locations was correct on the head.
Do you think it would be okay to run without the thermometer sensor ?
Thanks
Thanks
