Hello guys, I just bought a jacobsen utv sv3422. It has a D905E kubota 3 cylinder diesel engine. I bought it not running. The guy I bought it from had just replaced the injector pump. He also gave me a new 12v fuel pump with it. I got it home and tested the shutoff solenoid and it was working.
I then tested the fuel pump in it and it was working. I had fuel to the injector pump but nothing from there on. I then removed the injector pump and the plate below it that holds the linkage arms. Once removed I noticed a spring to the left just dangling inside. I also noticed the slider on the injector pump was on the back side of governor arm. So it could not be slid to the open position allowing fuel to run.
Now I've searched high and low on the Internet looking for images showing me where the springs go and how the linkage arms should be. And I cannot find anything for this setup. Hopefully somebody here can point me in the right direction. Thank yous!
