BX2660 weights
AshleyBS55
L245DT 4WD
Sep 30, 2013
86
Palestine, WV, US
I'm thinking of buying a 4' brush hog for my BX2660. The weight of the brush hog is around 400lbs. How much weight would I need on the front end to counter balance the brush hog?
Thanks
redmaher
253
US
Thanks
Shouldn't need any the brush hog should be set in its wheels and carry it's own weight.
Sent from my LG-H872 using Tapatalk
1,034
You will need weight for a brush hog or your steering will become difficult to get into a turn. The tractor is holding up the front of the mower.
I put 4 * 55 pounds on front of my L185 and that was enough. You can try less and add on until you are satisfied
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
306
98
Nicollet, mn
Do you have a loader? If so that should do it. If not a minimum of 200 lbs.
