B7100HST Question
bmwmike
B7100, 1640A loader, tiller, box blade, grader blade, carry all. John deere 455,
Jan 13, 2013
79
clarksville, Tn.
1995 B 7100 hst 4 wheel drive.
Does anyone know if I have to take the rear wheels off to pull out the strainers in the hst, to clean them? I have about 7" of clearance between the housing and the wheel, but I can't find any data on how long the strainers are.
My rear tires are loaded with liquid and I have 100 lbs of wheel weights on each, so if I have to pull the tires it's going to take some planing and more effort than just changing the hydro fluid, filter, and cleaning the strainers.
mike
2,203
mike
Mike,
Here is a picture from the WSM (item 16) ........hard to tell how long it is ! Let me know if you need the whole WSM.:)
Someone else will chime in and tell you.....I hope!:);)
Greenhead
L4400, MX5100
Oct 13, 2014
193
Fond du Lac, WI
mike
http://www.orangetractortalks.com/2...uction-screens-everything-you-wanted-to-know/
bmwmike
Jan 13, 2013
79
clarksville, Tn.
Thanks Guys for the information,
From the picture Greenhead provided the strainer is 7" long, which is about all the room I have .
Does any one know if both strainers are the same length ?
I was hoping that some one that had a b7100 and had done this would chime in. Mine has turf tires and they are set as wide a possible.
Does seem like overkill on this tractor to have a spin on hydro filter and two internal strainers.
mike
jcansler
47
I had a B7100 and could remove and clean the strainers without any problems with the tires on the tractor. I did have the wheels located on the axles to give the widest stance for stability. I also had the turf tires. Hope this helps...
Joe
hodge
Nov 19, 2010
2,861
372
Love, VA
I removed mine without taking the tires off- it would depend on where the hub is set at on the axle, I guess.
5,223
mike
You think maybe that's why they are still so many out there running strong? ;)
bmwmike
Jan 13, 2013
79
clarksville, Tn.
Joe
Thanks Joe. and Hodge
That is the information I was hoping for. I was not looking forward to trying to remove a wheel loaded with liquid, not counting the 100 lbs of wheel weights that have to come off. I will still have to remove one side of the rear sub frame of the FEL and put a bigger notch in it , but that is not a big deal.
And Wolfman you might be right about this helping them last so long.
Thanks to all who responded
mike
