B2150 No Start
kbrothers
b2150 HST loader/hoe
Dec 1, 2013
84
Ebensburg,Pa
My B2150 won't start Turned key to warm up ,when I go to start position, it clicks once and all dash lites go out Cleaned up ground frame connection and battery posts and charged battery Same thing Any help appreciated Ken
shootem604
Apr 23, 2018
875
British Columbia
Can you tell what clicks? Is it the starter or something else?
Did you check the seat and clutch safety switches?
Try a different battery, or a boost with jumpers? Sometimes they will charge and show the right voltage but they just don't have the amps anymore.
2,234
You have ....
a poor connection somewhere......
you have a battery that is supplying "volts" but not enough amps....
you have a very weak battery - it can happen for no real reason, poooof it is dead!
all of these can be tested.
Easiest thing is to do swap out the battery .....if that fixes the problem, you nailed it.
If problem was not solved - then you now can look at the other problems one on one.
kbrothers
Dec 1, 2013
84
Ebensburg,Pa
Click did not seem tb from starter;now the pre heat light doesn't come on Earlier I did jump it with my IH didn't make a difference tho
shootem604
Apr 23, 2018
875
British Columbia
I'd rule out the battery first and connections/cables first. Can you swap out the battery from your IH to check? If you still have problems, start checking cables, all connections, etc. Even with a new battery, cable, and clamps on vehicle once, it turned out to be a bad ground. I did also have a similar issue once that resulted from water in the key switch.
kbrothers
Dec 1, 2013
84
Ebensburg,Pa
Thanks for all the help guys It was the battery I had just charged it up and every thing looked good Guess ya can't judge a battery by its cover Ken
