I just added a rear weight box to the 3 pt hitch on my 23s so I could be more stable when mowing on hills. I already have filled tires and add front weights. I found to my chagrin that the lift on the mower deck is also the lift on the 3 pt hitch and weight box. However the lift on the mower only starts after the box is already lifted 15" off the ground. When the deck is up fully the box is 2 ft off the ground. Not very stable! Is there any way to adjust the mower so it starts lifting at the same time as the 3 pt.? Or alternatively just adjust the 3 pt down after the deck is up without affecting the deck height. I also use the lift on the deck to jump over hills and debris which is also affecting the ballast box. I have tried adjusting the top link to slow down the box lift height but it does not affect it much. Likewise the lift speed adjuster affects both attachments equally and does not start the deck lift at the same time either. Is there some way to adjust the hydraulics to start the deck lift with the 3pt lift? a
