Have to split the tractor and replace the propeller shaft ball joint on a B2150HST per this thread.
http://www.orangetractortalks.com/forums/showthread.php?p=328792#post328792
I have watched some vids and read a few threads. It seems every split is a bit different and some of the details and decisions may not be the best approach for this tractor.
At this time, I plan on replacing the propeller shaft ball joint only. No interest in replacing the clutch or throw-out bearing.
With that, how should I split the tractor - transmission or bell housing? I have read people doing both ways.
I posted two pics. One of the FEL bracket and the other of a hydraulic hose. Is removing the bolts labeled "B" the best way to unbolt loader frame from tractor frame? I am unsure about the hydraulic hose as I have no idea how robust the parts are that it attaches to.
Does the console have to be removed? .
Please keep in mind that I do not have power tools or a compressor and everything will be done by hand.
I have a very strong motorcycle lift for supporting and rolling the front half. I do not have a way to raise or support the engine with a hoist or chain. It should not require more then 2 inches of separation to r&r ball joint? At least this is what one person showed in his vid.
Also, I left the brush hog attached to the 3 point. I hope this was a good idea.
Lastly, apologies for the noob questions. Just trying to minimize surprises and mistakes.
