oil for B 4672 3 pt. backhoe
cliff c
b2920-4ft tiller-4ft brush cutter-rear blade-4672 hoe-front pallet forks-rear pa
Dec 5, 2017
Salt Spring Isl.
As this hoe has it's own pump and hydraulic reservoir and lines,do I need to use the Kubota UDT oil as recommended in the manual.
2,237
What else you have in mind? Do you have a Kubota dealer near by? Or you looking to spend a little less money on another oil?
cliff c
Dec 5, 2017
Salt Spring Isl.
there is no dealer close by,but there is a canadian tire and a walmart-----probably would be a lot cheaper too----thanks for the reply
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
If you want it to be smooth as silk order you some Amsoil hyd fluid. They'll deliver it right to your door and unless you use it a lot you'll not have to change it for years. It's rated for 3x the service life as standard fluid.
