ZD326 Transmission Fluid Drain
Five Acres
12
maryland
Hi
Working on changing the transmission fluid a ZD326.
Removed the very large drain plug from the bottom of the pan.
Pulled the dipstick.
Just over one gallon of transmission fluid collected in the drain pain.
Are there other drain plugs which need to be removed?
Thought there might be one on there right and left axle.
Removed the bottom bolt on the LH side but it was just a bolt and not a plug.
How do I get the other two gallons of transmission fluid out?
Saxman
L3830 ZD21
Jun 19, 2010
155
Mt. Vernon, IL
Both axle housings have a drain. They look like bolt heads but are actually drains
Five Acres
12
maryland
Thanks for such a fast reply.
Do you have a picture?
The one I removed looked like a Grade 8 with washer it was a long bolt. Pulled it out and it was dry with grass and dirt on the end.
