F FIRECREEK New member Equipment M9540 ZD28 Jun 26, 2013 1 0 0 Hockley Tx Jul 4, 2013 #1 2005 NEW BATTERY NEW GROUND,ALTERNATOR (DYNA) PUTTING OUT ABOUT 3V FUSES GOOD, ANY IDEAS OUT THERE? TROUBLESHOOTING
lsmurphy Active member Equipment B7001 Oct 19, 2012 1,197 5 36 Parrrottsville TN Jul 4, 2013 #2 3volts??????????? is that all????????? Bad alt.
S Stubbyie New member Jul 1, 2010 879 8 0 Midcontinent Jul 8, 2013 #3 When engine is running the voltage across the battery terminals should be about 13.8-volts DC. If not close, then bad alternator / dynamo.
H hillbillyss New member Equipment mower,box blade,bucket,boom lift,post hole digger Feb 25, 2013 22 0 0 greenville tx. Jul 20, 2013 #4 make sure it has 12v main and 12v exciter voltage to alt. then say bad alt.
