Z725 zero turn mower bolt pattern
aeronutt
Z725 Mower, MX5200 w/FEL, Stihl 660, assorted others...
Jan 7, 2016
120
Omaha NE
I'm just posting this as info for the next guy who searches for this info so they'll find it, unlike me...
Tire size: 24x12x12
Rim size: 10.5 x 12
Bolt pattern: 5 x 4.5 (very common on tons of smaller cars and pickups)
Backspacing: ~4 inches
Center bore: Doesn't matter. The hub is flat so the wheel is located by the studs, not a center bore.
Stud size: 1/2 inch
Socket required: 13/16
The clearance between the tread and the gas tank behind the tire on the right side is less than 1 inch, don't try running normal tire chains. They won't clear. The tread on mine actually makes contact (just barely) with the back of the mower deck when it is raised so if you need more traction, switch to a slightly smaller 23x10.5x12 tire with big tread. Good luck getting the bead to seat on that 10.5 inch wide rim.
Keywords: Z-725, Kubota, Zero Turn, Bolt Circle, Bolt Pattern, Mower wheels
