L Lizzard New member Dec 29, 2019 3 0 0 Spencerport Dec 29, 2019 #1 Hello looking for any video that would help me change my transmission oil and filter on a 2018 Z421 Zero Turn. Thanks in advance Lizzard
mikester Well-known member Equipment M59 TLB Oct 21, 2017 3,954 2,619 113 Canada www.divergentstuff.ca Dec 30, 2019 #2 Probably going to get as much info from the owners manual. If its anything like my zd326 get a sheet of cardboard to lay on and expect a tight squeeze.
M mickeyd Active member Lifetime Member Equipment 2014 L3200 DT w/LA524 FEL, 2019 Kubota Z121S w/ 48" Pro Dec, TG1860G w/RCK54TG Mar 21, 2014 1,192 18 38 Guin, AL Dec 30, 2019 #3 how many hours do you have on it? Are you changing both the engine oil and the transmission oil?
L Lizzard New member Dec 29, 2019 3 0 0 Spencerport Dec 30, 2019 #4 I have 112 hrs in and said it's a MUST to change the transmission fluid and filters. This must be the break in. Thanks for responding Lizzard
L Lizzard New member Dec 29, 2019 3 0 0 Spencerport Dec 30, 2019 #5 The purge process is a tad confusing so seeing a video makes it much easier when you see how. Lizzard
M mickeyd Active member Lifetime Member Equipment 2014 L3200 DT w/LA524 FEL, 2019 Kubota Z121S w/ 48" Pro Dec, TG1860G w/RCK54TG Mar 21, 2014 1,192 18 38 Guin, AL Dec 31, 2019 #6 Lizzard said: I have 112 hrs in and said it's a MUST to change the transmission fluid and filters. This must be the break in. Thanks for responding Lizzard Click to expand... You are correct, both oils and filters must be changed at the 100 hour mark. Then the next transmission oil change is at 400 hours.
