Won't go in 2wd
chip6700
b2320
Apr 9, 2010
virginia
I have a B2320 with about 110 hours on it. yesterday i went to use it and it only moved a few feet before it would go. the only way i could get it to move was in 4wd. It's a hydrostatic trans. it will move down hill, but the slightest incline and it won't move. i'm in louisa va and it's been down to 3 and 4 degrees at night. yesterday when i went to use it, it was in the 20's. i ran it for about 20 minutes and still it would go in 2wd. any thoughts.
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
Well, as we learned a couple weeks ago here on OTT, your rear wheels (rims) could be spinning inside the actual tire. Sounds hard to believe but try to lean over, without shutting engine off and see if rims are turning... also what happens when you step in the diff lock.
chip6700
b2320
Apr 9, 2010
virginia
thanks for the link steve and to quote FREDGARVIN "OMG, OMG OMG...Pete was right!!!"
turns out the right rim was turning. i'm sure the temperature had something to do with it, but what exactly caused it. it does have liquid in it, but i can't remember what it is.
