Wix 51307 (for L2501) cut open
Philly20
L2501 HST
Jan 5, 2016
20
14
I know. The dreaded oil filter thread. This post is for scientific/ informational purposes only! Brand new Wix that crosses (per Wix) to the Kubota OEM engine oil filter for a L2501. 55 pleats in all. If you wondered what the inside construction is like in these, wonder no more. Again, this is not an endorsement for wix or a suggestion that you should use aftermarket over OEM.
20210526_195916.jpg 20210526_195926.jpg 20210526_200904.jpg 20210526_200909.jpg
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,744
Kalamazoo, MI
It would be interesting if you cut open the Kubota filter to compare side by side.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
3,001
2,372
Western MT
I don’t expect to change my oil that many times that the price difference could be worth it. Also, without testing it, you have no idea if it filters better/equal or not. I do know that lots of people have blamed oil filters for a lot of diesel damage on trucks, so it’s not worth it to me.
mattwithcats
786
77
In that video, he is comparing the Kubota filter (HH150-323430) to a Fram PH6607 / Wix 51365...
Correct filter to compare to should be Fram PH7317 / Wix 51356...
Not sure why Fram and Wix have the wrong numbers....
4,293
I do not know of any filter OEM or otherwise...which will not run hot oil thru the media and return it to the sump.
I do not know of any healthy engine which will not run hot oil thru the filter on its’ way back to the sump.
The filter-quality question always seems to revolve around:
1-How efficient is the media (10 microns is typical of all media regardless of mfr’r)
2-How much junk the media will hold before media failure (closely related to total-area of media)
3-Whether or not an anti-drainback valve is incorporated (unimportant unless the filter is mounted open-end-down or horizontally... most Kubotas are hotizontal)
4-Cracking-pressure of the by-pass valve
5-Bursting-pressure of the canister.
I will postulate that ANY filter which has an anti-drainback feature will properly service a HEALTHY engine.... because a healthy engine will not be producing media-blocking Amounts of trash... and since media-blocking-amounts of trash are not being produced the media will not be overwhelmed, the by-pass valve will not be activated, the bursting pressure of the canister will not be exceeded, and the hot oil will properly pass-thru the media and return to the sump... exactly as it is supposed to do.
An UN-healthy engine will definitely benefit more with a higher-quality filter than a cheaper filter.... for the above-mentioned reasons.
If you have an old, nearly-on-its-deathbed engine you probably should be using only high-quality filters. However, when that trashy engine finally sheds it’s guts that filter is gonna jam and pass-along the trash to the sump regardless of what quality filter you have installed.
Still, I buy OEM-quality filters such as (first choice) OEM (Kubota in this case),.... (second-choice) Wix/NAPA,... (third choice) Luberfiner, etc etc. and I avoid Fram because they have documented-used cardboard-paper end-caps which quickly succumb to hot oil and shed paper-.particles into the oil-stream. I will use SuperTech/Purolater/Motorcraft on my lawnmower and generators but on my tractor and other expensive machinery I follow my suggestions in the first sentence of this paragraph....OEM.
