Why is my PTO lever stuck?
RCJC
Kubota 2380 BX with attachments
Mar 31, 2022
Morris, Oklahoma
It's stuck. Why? I can't figure it out. I can't start the tractor because it seems to be stuck in the on position. Help!
2,159
Disconnect any implements from the tractor and then see if you can get it back to the off position
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
If the brake is set and the transmission is in Neutral, you should be able to start the tractor even with the PTO engaged, no?
4,109
Lift your seat,, flip it up make sure the break is set and see if it will start, it is designed to up with the seat up for things like PTO gen sets. If it starts jiggle the PTO lever and see if it turns loose,, just a thought
