White smoke?
Codi
Kubota B9200D bush hog, finish mower, carry all, box blade
Jan 17, 2016
66
Northern Kentucky
This hinges on my fuel bleeding question.
So as you guys know I replaced the glow plugs in my B9200D. One tested bad so I replaced the whole set. That seemed to solve the rough starting issue as well as the majority of the white smoke issue. However, while it starts much easier it does still puff a few short puffs of black smoke on the first start up. And only on the first start up. I know before I got it, it did sit for a bit in my papaw's cold garage. Cold some air in the system cause those few puffs of white smoke?
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
this hinges on my fuel bleeding question.
So as you guys know i replaced the glow plugs in my b9200d. One tested bad so i replaced the whole set. That seemed to solve the rough starting issue as well as the majority of the white smoke issue. However, while it starts much easier it does still puff a few short puffs of BLACK smoke on the first start up. And only on the first start up. I know before i got it, it did sit for a bit in my papaw's cold garage. Cold some air in the system cause those few puffs of WHITE smoke?
Sent from my iphone using tapatalk
what color smoke?
Codi
Jan 17, 2016
66
Northern Kentucky
White... Sorry auto correct changed it. First start up of the is a little white then the rest of the start ups through the day are as normal with a little puff of black.
8,819
I wouldn't worry about it. What your seeing sounds normal. Especially if it's starting and running fine. :)
