Where to purchase decal set B7100
Mike in Littlestown
B7100
Jan 24, 2021
39
11
Littlestown, PA
Title pretty much says it all. I see some sets listed on eBay, but they come from the UK. If possible, I'd like to get a USA source.
How expensive is it to buy them from a Kubota dealer?
Are they generally in stock?
Does Kubota offer the decals as a set at a reduced cost?
I am looking for the complete set; not just the hood decals.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
I had to buy some in small groups, and some as individual pieces. It was a bit of work to make sure that I had identified all of them. I bought them to put away for the time when I will need them, because you know that they won't be available by then. Use the parts lookup to find stock numbers. Use a dealer to purchase them. You can find some of them on E-bay. I don't know if they fully match the original or not.
I would guess that a full set will run you a couple of hundred bucks (tractor, front loader)
SDT
multiple and various
Apr 15, 2018
3,311
1,102
SE, IN
Kubota sells individual decals but generally not sets.
No, your dealer will not have such in stock so you will need to order them.
Expensive but probably available.
SDT
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
My loader arm decals were pretty scratched up. I found a load of them available on ebay. I did not go with the exact replacement. I found one that I liked better :)
2,060
If I recall Kubota uses the word label for these. I have found them strung in most parts of the parts list but most are in the area of fenders, hood, dash.
If you’re able to read your existing labels it would be cheaper to have them made probably, and you would be able to use better “English “ than the labels will have.
If you want me to send pictures of the labels I have to your e-mail let me know
