wheel locking up
willyt78
b21
Dec 15, 2011
pennsburg pa
Front right wheel sometimes locking up. Going in reverse will release it. This just started. I am in 2 wheel drive at the Time . Low gear oil? This is a B21.
Breeze
L3700, Box Grader, 60" Bush Hog, Rear Grader Blade, York Rake, Boom Pole.
Dec 24, 2010
149
Virgin Islands
Low gear oil isn't causing the lock up but may have caused the problem that results in a lock up.
I'd start by looking at a parts diagram of your tractor's front running gear and pay particular attention to bearings. Any noise when it is rolling? Bearings and gears are first cousins with bearings being the least expensive to replace, by far.
The problem could be at the affected wheel or the differential as I assume you have 4WD.
In any case, I'd open it up for an inspection before the problem becomes worse and start with the wheel. Jack it up, rotate the wheel by hand and give a good listen first.
Wbk
307
St Adolphe Manitoba Canada
HI I assume you have drum brakes up front, if so it could be as simple as a broken or dislocated brake shoe spring. I would pull the drum and check it out because it's only locking up on the rt wheel start there. Hope this helps Barry
Breeze
Dec 24, 2010
149
Virgin Islands
Good call Barry!
Hopefully the OP will report back.
kubotasam
Apr 26, 2010
1,209
132
Alfred Maine
I am no expert on B21's but I am fairly sure there are no front brakes on his tractor.
Check bearings and gears in the front end.
