What's your L-series rear tire pressure?
domigold
L2501
May 6, 2021
15
Atlanta, GA
The doc said 30psi. I found it to be too rough. Thinking about letting some air out. Perhaps to 15psi. What do you run yours at? Thanks.
B2710
LX3310, L45, RTV1100
Dec 13, 2011
42
26
SE Tennessee
I have filled R14 tires, OM states 32 psi, I run 12 psi now after several weeks lowering it by 5 psi till I found a comfortable yet operational pressure. Your may be more or less depending on tractor weight and attachments.
bucktail
Jun 13, 2016
1,257
190
MN
About 15. I put my heaviest implement on and aired them up until they stopped squatting.
pokey1416
Jun 24, 2020
567
843
SW Michigan
20 as I have the heavy BH92 on the back most of the year. R4 tires.
domigold
L2501
May 6, 2021
15
Atlanta, GA
In my loaded R4, I have it a round 20psi. I'm thinking about lowering it a bit more to 12-15psi to help with traction. Thought I double check what's everyone else is doing. Thanks everyone.
woodsy
95 Kubota L3300DT W/FEL, 60" AgroTrend 3pt snow blower89 Arctic Cat 440 Panther
Apr 20, 2021
132
60
Maine
I checked mine today after having the local tire shop over for getting ballast
in one 12.4 x 24 AG and a new outer valve stem in the other.
Let air out of both tires till I hit 20 PSI . Roll bar top bolts no longer
scraping the shed door header. Ill try this PSI for a spell but will probably let more out per the majority here. Currently have no 3pt implements .
CKNPRO
L4701 HST
Apr 16, 2021
Alabama
ballasted R4’s on 4701 at about 12# rear, 25# fronts air only. With that I still am a little too rounded but I haven’t dropped it any more. I’d guess I’m getting 90% tread contact on hard surface. Still rides a little rough for my full satisfaction but that’s just R4 for ya....they be stiff!
