what thread on rear lifting rod
Colb56
Kubota B2601
Mar 5, 2024
72
PA
Hi all,
Hoping to find what thread is on the right rear lifting rod on my B2601. I bought this used and went to adjust it last week and could not adjust it in or out by hand. I disconnected the bottom and I can run it in or out very easy. The top that is connected to tractor would not budge unless I put a bar through the part on the barrel with a rod. I took it off and finally with some difficulty got it apart. I cleaned all the greese off real well and noticed that there are 3 threads that are buggered up. Not real bad but enough that I would have to use a bar to rotate it up or down to make the fine adjustments.
I was going to see if I could find somebody around me who had a tap and die set. I didn't want to have to buy a new one....$150.00 I figured I would run the tap and die on the threads and it should be just like new. I assume they are metric ?
2,043
They are probably 3/4 thread, probably coarse pitch. One will be right hand and one is left hand thread. You can measure it pretty easily.
