What is this?
airbiscuit
New Holland T2310, New Holland TC21D, Kubota l3010 GST, Farmall H
Mar 18, 2021
304
298
NW WI
3 Point Speed Control Knob
Start at :30
je1279
LX2610 w/ 60" MMM, LP 72" Snow Plow, EA Wicked 55" Grapple, and Woods 60" BB
Dec 6, 2020
828
581
Upstate NY
I know on the LX cab models they have the suspension seat adjustment in that area. For the ROPS models, there is a T bar behind the seat to adjust suspension stiffness/travel.
kubotafreak
Sep 20, 2018
1,049
394
Arkansas, US
I sat on the seat and moved the lever up and down and it did absolutely nothing.
Actuate the lever as your pushing the seat back or forward. I could swear it is the slide lock. The knob is the three point hydraulic return adjustment. The lever is in question right?
Andrew270
L4060le, fdr1672, rcr1260, rta1258, 1957 ford 871
Mar 5, 2021
22
15
Symsonia ky
Has anyone suggested a lock for a seat swivel? Just asking because I found one on mine today. Although no backhoe and not enough room to turn completely around it's still there.
5,569
I'd go online to a 'partsplace', find the diagram for your tractor seat area, the item should be described and the picture will show how it's used...
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
323
87
Bagley, MN, United States
If you look closely at the video you will notice that he is tipping the handle to use for leverage to turn the rod that it is connected to - the 'lever' is just used as a device to turn the rod ccw or cw to either adjust the seat suspension for more or less resistance.
Parrothead127
L2501 with FEL
Apr 3, 2021
19
East of Atlanta
I'm not talking about the knob but the lever above it
my bad trad, I’m stumped. It looks as though it is the lever to adjust the seat back and forth, but you mentioned it didn’t do anything. I’m curious too, so I’ll be looking forward to the answer as well. I’m supposed to get my L2501 this Saturday so I’ll check it out when it gets here. Could it possibly be for adjusting the forward/back adjustment of the seat and you could have some “trash” in it causing it to bind?🤷🏽
