I lost a drive shaft in my L245DT transmission and had to split the tractor on both side of the transmission. I took off the clutch pressure plate to inspect the clutch disk. Then I read the instructions when putting the clutch back together. Service manual is from Kubota. It stated to make sure and put the clutch disk boss back in the right direction. Well it does not say what is the correct direction is and what a clutch disk boss is anywhere. Parts manual has no mention of it. I'm assuming it is the disk. But what still is the correct direction.
