weight of B2601 with FEL and BH ?
miketrock
163
Pa
I've been searching but cant find the info … How much does a B2601 weigh with a Front end loader and a backhoe ? A B2601 weighs1632 lbs. but cant find the implement weights …
4,645
found these:
Tractor= 1632 lbs
LA434 = 459lbs
Bucket approx = 200lbs depending in size
BH70= approx 705lbs
BH bucket+ approx 70 lbs depending on size
3,066 lbs total
miketrock
163
Pa
Ok, thanks ... tryin to figure out how much trailer would be required for its weight and length. Probably a dual axle, 5000 lb or 7000lb, 16'- 18' .
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
7K. Figure 1-2K for the trailer weight, that would leave you with a comfortable margin.
Longer is always better when talking about a few feet. Better ride, easier to balance out as it gives more options.
4,645
If you're really looking for used, I may be selling mine soon.
It's a 7K holmes tandem landscape trailer (16ft) with heavy duty gates, 2 foot sidewalls. 5 new tires. Electric brakes on both axles. Alligator spring assist gate lift.
I'm now looking for an 18'-20' aluminum. My 16 footer is a tad short for my B2650.
3,342
Also, longer trailers allow you to carry addt’l implements along with the tractor (other than the ones attached.)
