Voltage to glow pligs?
unioncreek
Kubota L3710 GST
Nov 1, 2023
57
WA
I have a l3710 and it seems like it takes longer to start now that its getting colder. I changed the glow.plug relay and the other small black box associated with the glow plugs because the glow.plug light was on almost constantly. I checked the voltage at the glow plugs today and the DVM showed 8.3 volts. Everything I can find says it should be about 12 volts. What would cause the lower voltage?
BX23-S,57 A-C D-14,
6,344
'high' resistance in the wiring. Each glow plug usually draw about 10 amps of current,so you need real good clean connections. 4 glow plugs need about 40 amps of power. ANY corrosion in the wiring will reduce the current capability, so voltage goes down. Similar to the grr-rr-rr of a starter not getting enough amps. You might get lucky, disconnect battery, remove all glow plug wiring, clean and reinstall. See if that helps.
Jim L.
895
183
It might be useful to use a clamp-on DC ammeter to find total glow plugs current before cleaning.
Then again after cleaning.
Another diagnostic is to measure differential voltage across connections. A high resistance (bad) connection will have voltage drop when current is passed thru it. You can isolate your bad connections to fix.
unioncreek
Kubota L3710 GST
Nov 1, 2023
57
WA
Thanks Guys.
I bought the tractor a couple of years ago and the glow plugs have worked good. When the light was coming on while I was using it I new I needed to change the relay and controller. I'm planning on checking all the wiring and connections. Hopefully that fix the problem.
Bob
