Valve Adjustment?
300zx
Dec 1, 2010
445
Forest, VA
How do you know when to do an adjustment on the valve lash? I have a B7100 with 1300 hrs, a B6200 with 2300 (guessing) and my son has a b6100 with unknown hours.
John in VA
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
John in VA
The obvious one would be one would hear them tapping if loose.
If they are tight the engine would run uneven which is harder to diagnose as it could be caused by other causes.
In the absence of any symptoms I check the clearance as part of bi anual service which for my b7100 is around 100 hours but as a matter of course on a new purchase
Dave
3,293
When I got my B7100, previous owner maintenance was at best, suspect. I did not think that it ran rough or that the valve train was noisy, but I was stunned at how much smoother & more quietly it ran after adjusting the valves. I would check & adjust them (if necessary) just to establish a baseline. Mine were all loose, & a couple were .020-.022. :eek:
300zx
Dec 1, 2010
445
Forest, VA
Well, I will get some valve cover gaskets and go to work.
Thanks guys,
John
B7100
Feb 11, 2010
422
Wales
Thanks guys,
John
If you slacken the retaining nuts off, give the cover a sideways tap with a rubber hammer and it comes loose,you'll probably get away without a new one.
dave
Orange Tractors
Jul 19, 2009
323
Butler, MO
dave
That's IF the valve cover has ever been off. I don't think the vavle cover had ever been off on my L175.
When we first got it running, you could tell the vavles needed adjusting; but just attempting to loosen the two vavle cover bolts made a change in the vlaves. Very strange, but it did lead to me discovering this very helpful website.
One of my first questions was to find out the proper vavle lash for my tractor.
Robert
B7100
Feb 11, 2010
422
Wales
If loosening the rocker cover nuts changed the note of the engine them may be the decompression lever was out of adjustment.
Dave
Orange Tractors
Jul 19, 2009
323
Butler, MO
Dave
My thoughts too Dave
You guys are right, the decompression lever was also way out of adjustment. The handle is broken from it, so right now I have the decomp adjusted to not touch anything. One of these days I will replace it and get everything in spec.
Going from memories (3 or 4 years anyway) my valves had anywhere from .016 to .022" clearance, when the book calls for .007-.009". I know the seat of the pants dyno said I gained about twice the HP when I had them set properly.
Robert
