Used M9960
Olemax
L4240 HSTC, Blue Diamond Grapple, Landpride RBT35, Bushog SQ 84, 8' JD KBA
Dec 5, 2017
Jefferson, NC
I am looking at a 2013 M9960 with really low hours (less than 400). Are there any hidden surprises to be aware of? I have no experience with anything later than M7040. I'm particularly concerned about the DPF and other emissions. How long does it take for any error lights or messages to appear after starting the engine?
Thanks in advance for your help,
Olemax
Thunder chicken
M7060
Dec 29, 2019
300
123
Northern ontario
I bought a 7060 used a few years ago with just under 300 hours. Now at 600.
it regens as the manual says. The light comes on, if you can’t remember what to do, there’s instructions on the sun visor (if it’s a cab!). You simply raise the RPM till the light stops flashing and it will start it’s cycle. Keep working. Or ignore it and do a parked regen later. (Park, raise rpm, push button, walk away). Takes less than 10 minutes. It’s not a big deal. Yes it’s more annoying than a non dpf machine. I deleted my VW because of the unreliable system. If this machine requires repair out of warranty, it will be deleted as well.
It will regen more often if left idling long periods, especially during the winter. (Think warm ups). Or lots of low rpm light duty work. I’m on the road at WOT a lot pulling a trailer so it’s working and I bet I average a regen every 50-75hrs.
Finding a few year older low hour non DPF machine is likely harder. However, I don’t think this system (from my few years of using) is unreliable (compared to the VW, and hearing friends with dodge trucks complain)
I’d be more concerned with all the other little things with a low use machine like all the hoses and belts, water in fluids, seized controls (3pt lowering control, draft linkages etc), rubber boots.... was it in a shed or in the sun?
SDT
multiple and various
Apr 15, 2018
3,383
1,162
SE, IN
Olemax
I have an M9960 ROPS bought new in Jan 2016.
Though I do not use it much regeneration has been seamless.
Weak PTO brake was redesigned during the M9960 model run. The one that you are looking will have the early (weak) design. Not an issue if tractor not used regularly with high inertial PTO loads, e.g., BW mower, etc. Try to determine what PO used tractor for.
SDT
