Disclaimer: If you want a cheap, efficient and easy method to wire-up a set of auxiliary lights on your Kubota tractor…this is NOT the method for you.
The rabbit hole that I went down from start to finish on this ‘project’ was deep. I am not a professional mechanic, I am not a professional low voltage electrician, I am not a professional Kubota technician. My tractor is a part tool, part ‘toy’ (mostly toy)…therefore I took this project on with that in mind. I needed (wanted) auxiliary lighting, I needed (wanted) to figure out if it was possible to wire the lighting up with OEM lit Kubota switches. I’ve been learning (teaching myself) more about electrical/wiring in the past few years after being very averse to it for a long time. Therefore, the goal (hobby, exercise, etc.) for me was to learn something new and figure out if it ‘could’ be done…I fully acknowledge there are faster, much cheaper, easier ways to achieve the same result of what ended up coming to fruition here.
So…the problem at hand is that you want to install a set of auxiliary lights on your Kubota tractor (in my case an LX2620SU) but you’d also like to use OEM Kubota switches in the square dash knockout holes, because the thought of having a non-OEM switch drilled/cut into the dash makes your eye twitch?
In my case, I ordered two push-button Kubota OEM switches (K2110-62810). These switches have a built-in light that will illuminate under 12V power. They are push-button momentary style switches, NOT toggle switches. They have four pins on the back of them. Two pins are for the switch itself, the other two are for the light on the switch. I used a small 12v battery, a few test leads and a multimeter to figure out what each of these pins actually did.
Originally, after discovering these were momentary switches, I planned on returning them. This is where the beginning of the aforementioned rabbit hole started to tunnel much deeper. After some research I discovered that using a latching relay (CZH-LABS MD-D1022B/12V-1) could allow the use of a momentary switch to create the same effect of a toggle switch. The latching relay contains a small circuit board and a relay that responds to a ‘pulse’ to switch and hold the relay from open to closed, or vice versa. The ‘pulse’ in this case is simply the press of the momentary Kubota switch on the dash.
So, using the relay, the auxiliary lights get power through the latching relay itself, with the Kubota dash switches telling the relay to latch (remain) open or closed (turning the lights off/on, respectively).
Next is addressing connectors on the back of the switches. The factory Kubota switches have a specific connector on the back that will plug in directly. Through (endless) searching on the internet I found that connector itself is a Sumitomo MT .090” ‘SPA’ connector (Sumitomo parts 6242-5061 and 6242-1061 for the male/female components). The switches referenced above will need the male ends and their respective terminals. When wiring these switches you will need 4 wires, a positive/negative for the switch light and a positive/negative for the pulse to the latching relay. The connectors accommodate up to 6 pins, but for these switches I only needed 4 for the wiring noted above.
I ended up getting two latching relays (one for the front aux light bar and one for the rear aux lights). I made sure that the main power feed from the battery was fused up near the battery. I added another fuse block that had 4 separate circuits to break the power up as needed to the respective aux lights and their mated lit switches. This is all wired into a waterproof aluminum box mounted where the factory plastic toolbox used to live. I added an additional ground bus bar next to the box (but below so it was concealed) to grab the exterior grounds. I used a handful of Wago wire connectors to splice the power around or extend the grounds as needed.
One item to note, the latching relay is only good for like 8A or so, so added a typical 30A 5 pin relay that receives its signal from the latching relay. The only purpose for this additional relay was to pull the additional amp draw from the light bar off of the weaker latching relay and dump it to the more robust 5 pin relay, while still preserving the switch and latching relay behavior.
An additional item to note, I added a bunch of 3W resistors in parallel to the power back to the switch lights in an effort to reduce their brightness. The lit switches are quite bright and angled right at you in the dark, and I wanted to dial it back a bit. Five 3W resistors in parallel to achieve 80 ohms was sufficient to dim the switch light a bit so it was less ‘in your face’ when on. Make sure you use 3W resistors, the smaller ones just get too hot.
So, there you have it…far too much work that I learned a ton from and now I have OEM switches operating my lights. A few photos below of a lit switch and the box with wiring. Happy to help with any questions both on how to make this work, as well as why I am stupid enough to do it verses cheaper and easier methods. Hope it helps someone out there.
