I found a BH77 locally-ish to me (around 2 hours away). They don't pop up too often at a reasonable distance. It's the backhoe only, no subframe kit.
Gentleman indicates he bought it in 2018 new with his L3301 and didn't use it a ton. He was asking $6000. This was too high to begin with, but was a reasonable starting point. I told him I'd need to see the unit operate on his tractor before buying. He told me the following:
"To be honest if you're really serious on this I'd rather not hook it up it has a small leak from a round thing under all the hoses was told it's probably an o ring from sitting and never used everything else works great I had to use every function to unhook it I can line up a skid steer to load it for you and show you what I'm talking about otherwise it's brand new there's still paint on the bucket"
I'm waiting for better pictures of where the leak is coming from.
Couple of questions:
1. What is the risk of the entire control valve assembly going bad? Sure it could be a $1.00 O-ring, but I see the control valve assembly is a $5,000 part.
2. I presume that the control valve can be tested by testing the operational pressures - I assume an o-ring leaks, but a control valve assembly failure impacts the functional or pressure capabilities of the system.
I like to work on things but I obviously don't want to spend $4,000 on the BH and $5,000 on a control valve when I could just buy a whole new backhoe for that same price.
Thank you,
Thank you,
