Upgrading to Nokian Snow Tires fitment question
mtnplower
Kubota L5740
Jul 15, 2022
72
Sierra Nevadas
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
Your 16.5 rims are the biggest issue. I just checked some pictures I have of a L6060 and it had 250/80R16 and 400/80R24 tires. So I am thinking you will need different rims as well. ???
pokey1416
Jun 24, 2020
567
843
SW Michigan
Watch this video, not sure if it helps but just past halfway he talks about swapping tires on the L60 series.
mtnplower
Kubota L5740
Jul 15, 2022
72
Sierra Nevadas
thank you for the info, so what would be the best rims to buy for it to run the Nokian Tires?
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
The fronts would be the ag rims for the 9.5 - 16 tires. The rears I am not sure. You would need a rim for a 16.9-24 tire. I will think about it and see what I can come up with, but no promises.
Tractor Tire Conversion Chart (yournexttire.com) This is the chart I use to cross reference tires.
Have you talked to your dealer or a tire shop ? Probably not common in your area, here it is.
But now we are assuming both tractors have the same ratios, and that is a dangerous game to play. If they are great, if not, your could be out a bunch of $$$.
mtnplower
Kubota L5740
Jul 15, 2022
72
Sierra Nevadas
Thank you for the tire conversion chart thats an awesome reference
I appreciate your help in finding the RIM I need
I did speak with a Kubota dealer and here are the options
So what would be the best Rim setup for the Nokian tires?
Fronts
9.5x16
10x16.5 (already installed)
10.5x15
12.5x15
Rears
14.9x26
17.5x24 (already installed)
41x18x16.1
6/10/70 (whatever that means)
mtnplower
Kubota L5740
Jul 15, 2022
72
Sierra Nevadas
Looking at Nokians website it looks like they have some tires that are pretty close in size to the rim width
For the Fronts Nokian has these sizes available
250/80/R16--- Will that fit on the 9.5x16 RIM?
Nokian has these sizes available ----------Which tire fits correctly on the 17.5x24?
440/80/R24
420/65/R24
Vigo
B6100, B8200
Jan 9, 2022
595
341
San Antonio Texas
The 250/75/16 says it will fit on a 7-9" wide rim, so you're fine there.
The 440/80/24 is a lot closer to the diameter of the 17.5-24 than the other one, but still slightly taller. At least from the calculations.
