Turning up a D1105
natesword10
D1105
Sep 20, 2022
Any idea what i have to do to turn up fuel on a D1105? Planning to put a decent size turbo, or two smaller compounds. Are there any options for larger injectors or pump modifications? Any knowledge helps as i’m just trying to build knowledge before i do anything.
Rdrcr
Vendor Member
May 7, 2021
749
925
WA
What's your definition of a "decent size" turbo? Why would you want to run compounds on that engine?
The D1105 is a 1.1L. I'd recommend nothing larger than a MHI TD025.
Unfortunately, I'm not familiar enough with your engine to help with the fueling or injection pump questions.
What are you trying to achieve with the turbo upgrade? Are you planning on running some large implements or attachments?
Mike
