transmission oil?
SidecarFlip
Banned
560
Probabaly. Heck each of mine holds just under 15 gallons (59 quarts to be exact) and neither are hydrostats either. You have a cheap date.... :D
BigG
Sep 14, 2018
1,951
774
West Central,FL
Did I read right? My little 2380 holds 12 quarts hydraulic fluid?
If you are doing a hydraulic oil change DO NOT DUMP 12 quarts into the tractor. The oil will not drain out 100% therefore you must check as you fill to insure that you do not over fill the machine. Once it is full start the tractor and let it run for several moments then recheck the fluid level.
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
219
47
Dickson, TN
Yep. I will be due for a full service next spring.
BruceP
G5200H
Aug 7, 2016
852
371
Richmond, Vermont, USA
I got out of it cheep.... my little G4500 HST takes 7.5 quarts.
When I was in the Kubota shop today, the cost difference between 'normal' UDT and the 'super' UDT was only $8 more for me so I splurged for good stuff. (Much of my tractor-work is pulling driveway scraper)
